Posted by Owen Aaland on September 24, 2007 at 11:25:50 from (65.174.247.81):
In Reply to: 560 steering problem posted by Wredt Farms on September 24, 2007 at 10:03:54:
The 560 steering is a manual system with hydraulic assist added. Since it works OK with the tractor not running the problem is in the hydraulic assist part and not a mechanical problem. If you are sure there are no problems in the control unit the other posibility is a blown O-ring seal in the front bolster
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
