You can buy conversion kits from many sources, including this site. Also complete three points if you don't have a fast hitch. I once saw a 560 on a sale that had had the lower part of the fast hitch removed and three point arms attached to the bottom of the brackets behind the axle housing that hold the rockshaft for the fast hitch. They used the fast hitch rockshaft, cylinder, and upper lift arms to operate the three point. With this setup you would have to use a cross drawbar or fabricate a swinging drawbar for drawn implements. Lee
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
