Steve: The M&W pump will work on the M Diesel or M Gas engine... The only thing is the Diesel engine turns CCW and the Gas turns CW... If the drive (52927DA) gear was swapped for the gas (*******) Gear, it should work.... Cause this pump, will pump, <--- * ---> in both directions.
There is a M&W pump for a W6 or Super M on eBay... I don't know if it will fit your M or not.... Just go to Google, type in "M&W LIVE PUMP" Without the ("") Quotes and you'll see it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
