Posted by ejr-IA on November 24, 2007 at 10:45:16 from (204.11.182.54):
In Reply to: IH 706 miss posted by Melvin Shaw on November 24, 2007 at 09:26:29:
Which cylinder is the miss in?It could be carbon under a valve or a burned valve.The exh. valves on two cylinders are next to each other and can burn between each other that can cause a miss between two cylinders they are 2,3and4,5 or maybe one cylinder with bad compression.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
