Posted by Bob Kerr on December 09, 2007 at 07:44:35 from (64.12.116.73):
In Reply to: M Farmall Maintenance posted by Iowa47M on December 08, 2007 at 23:25:48:
If you don"t already have one, get a grease gun and go to town with it. There are a few hidden grease fittings like one or both on the water pump and for the clutch parts and hand crank. Get an operators manual to find all the fittings. Don"t over grease the water pump or clutch pilot bearing, half a pump will do there. there is also a couple plugs on the distributor. Check the rear end grease. And with a loader on it be sure to check and regrease the front wheel bearings as well as the front bolster.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
