Posted by VA Gasman on December 15, 2007 at 04:22:18 from (208.103.140.130):
I've been using super H for 4 years now . When I got it it was stored on sale lot. The brakes would not engage. I put new discs in and then learned from a friend about the little steel ball bearings in the plates that would get rusty and not allow plates to do there job. these continue to rust from being idle for periods of time. can they be lubricated ? I once used dry caterpillar brand lube; it worked for a while .Does one replace the steel balls?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
