Posted by Mifsud on January 15, 2008 at 18:18:12 from (207.200.116.7):
Looking to replace the Mag on a cub (1947) with a distributor and coil set up I already have. It is a 6 volt set up. Need to know the proper way to replace one with the other. The original mag is still on the tractor but for some reason the inner parts where removed. I have the head off of the tractor now because I just lapped the valves. Never replaced one before so I need some good info. on the correct procedure. Also how do you check the coil to see if it is 6 or 12 volts. Thanks
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
