Posted by Andy Motteberg on January 31, 2008 at 22:36:14 from (4.143.216.188):
In Reply to: Re: H on Steel posted by Greg-N-CA on January 31, 2008 at 05:51:37:
If it runs, I'd guess around $1500 or more. A full set of steel is very rare. I know they are "worth" more than $800 as Mike said, everything on eBay is going cheap lately. The front steel might be worth almost that. If it does not run, loose, around $1300, if the motor is froze up, probably around $1100.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
