Dave: In addition to what Hal has said, think about the possibility of ice in the carb. My 130 has done this 3 or 4 times this winter. Had the carb off twice couldn't find anything wrong. It's not coil as it fires right up within seconds. Acts as though fuel supply is restricted. I also notice I'm getting a slow buildup of water in the sediment bowl. Finally I dumped in 1/4 cup of methyl hydrate, cured it almost instantly. It's happened twice since and each time methyl hydrate cured it very quickly. Somewhere, I'm getting water, we are having a lot of fluctuation in temperatures, above and below freezing, I'm thinking condensation is my problem.
May be since oil hit $100./ barrel earlier my refinery has increased the volume of water in the gas to make more money.
Heard a story years ago, farmer trying to squeak through some hard times, tried mixing sawdust with his horse feed. He said it worked well at low percentages of sawdust, but once he got to 40% the horse died. I'm thinking I've got .01% water, I guess an offset Farmall, just a bit more sensitive than the horse, however the Farmall will come back to life, if one corrects it's feed.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
