While tractor is stationary, turn the steering wheel back & forth & look at the top of the left spindle to see if there is play between the arm & the spindle nut. If there is play here, it could be loose splines at the top of the spindle or bushings as mentioned before. A third possibility is a worn-out thrust bearing which is at the bottom of the spindle where the axle hub is located. If this area is satisfactory, jack the left side of the front axle up & check the wheel bearings with no load on them. Have you checked the tie rods???
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
