Posted by Greg-N-CA on March 03, 2008 at 05:55:31 from (4.246.212.87):
In Reply to: SA touch control con't posted by P and R Pete on March 02, 2008 at 18:05:57:
I finally found the source of my rattle. After putting the block on my engine stand to spin it over quickly, I identified the noise to be coming from the top of the block. I popped out the expansion plug and found a broken piece of cast trapped between the cylinders. I now have a souvenir from the factory!
I pulled all the passageway plugs yesterday and cleaned everything out. I only found a few of the plugs to be hiding dirt and old fluid, it was worth while. I was able to remove the safety valve piston with a pair of jeweler’s needle nose pliers, but I still cannot get the pressure regulator valve seat out.
Pete, you were right, the front of your control block was a "cruddy mess." Glad you got it apart; I hope Sam is making progress too. The YT forum is a GREAT venue, how else would those of us doing the same project across the States be able to share like this? Awesome, thanks!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
