Posted by Matthew Williams on March 11, 2008 at 20:13:08 from (208.195.70.41):
I tried to do a search as I am sure it has been covered before but failed. I need to remove the cover of the resevior and understand that it has to come straight up or I will crush the strainer. I have everything ready to go and it looks like there are four places to screw bolts into to lift up with but they are located on the back 1/2 of the cover. Is there a trick or do you just push down on the short end and hope you are strong enough? Any help greatly appreciated, esp. pics! Also how would you flush the system, the reason I am taking the cover off is that I put some bad fluid in and wanted to get as much out and clean the filter. (Somehow stuff go in the fluid and I didn"t notice until a couple clumps had fallen through.) Thanks!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
