I have had mine off several times. But I am quite sure I never have, or never will, do it right. I run a 1/4" chain under one of the straps that hold the seat and snug the bolts on each end of the strap. Then put a loop in the chain, run another length of chain around the hydraulic controls and put a loop in this chain to match the loop in the first chain (otherwise, mine wants to tilt toward the controls). Then, I have used both a chain hoist and a come along to hook through both loops and lift it straight up. Then, I have been able to do what I need to do.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
