Posted by JMS/.MN on April 26, 2008 at 08:17:15 from (209.237.107.155):
In Reply to: Need Yer Brain posted by Allan In NE on April 26, 2008 at 07:51:21:
Brain is available- should be just like new, some say it"s never been used. I"ve heard of tracting leaks by using a low wattage bulb/socket, disconnect one wire at a time, short the pigtails to wire/terminal and ground. Glow should indicate the leaker, no glow, wire it back up. Only need one wire loose at a time.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
