The 3 turns out is not necessarily the factory setting, that is just to allow it to start. Once ruuning and warmed up, open the throttle all the way, then turn the screw in until the engine begins to stumble, then out until smooth plus maybe 1/4-1/2 turn more. Leaner is better. Adjust the idle mixture screw also. Both may need to be done more than once. On the other hand, the main screw on the Super H and M, is set at the factory 5 turns out. Different carb.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
