Re: 460 Farmall carburetor tuning
Posted by CNKS on May 19, 2008 at 17:21:09 from (216.144.104.128):
In Reply to: 460 Farmall carburetor tuning posted by CtryBoyInMT on May 19, 2008 at 14:55:40:
Your carb needs to be cleaned and the float adjusted properly. By cleaning I mean soak in in carb cleaner overnight and blow it out with compressed air. Otherwise your new parts will do no good. You have found the main jet. Max power is 5 turns out, will probably run with 3-3.5 out. The screw can be turned in if you do not need max power. Otherwise it is a "fixed" jet, and "adjustment" does not affect the way the engine runs unless you turn it in too far. The other 2 screws are idle mixture and idle speed. Look closely at them and you can tell which is which. The gaskets do not need any kind of sealer, more harm than good if the sealer gets in the carb. You could also have a governor problem or a leak in the intake manifold.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
