Posted by Gene Bender on June 18, 2008 at 18:52:34 from (67.55.226.165):
In Reply to: W4 Drawbar (Hardening) posted by Eric Bergstrom on June 18, 2008 at 14:01:44:
The W-4 dont have enough power to straighten out the bends and unless you pull a plow for three wks you sure aint going to eggshape the hole. Using a pto baler would do the most damage but a little grease on the pin sure would make a difference so stop worring you will be just fine.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
