If the tractor has been sitting for any length of time, the gas in the carb has turned to varnish and cause the needle valve to become sticky. Tapping on the carb will loosen it up a bit, but only temporarily. It is also quite possible that the hinge pin for the float has become sticky and the float cannot drop as needed. Probably your best option at this time to get a can of aerosol carb cleaner, take the carb apart and clean the needle valve and seat, as well as the float and the hinge pin. Probably will not need a complete rebuild, but you probably will need a new gasket for in between the top and bottom carb halves.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
