Posted by CNKS on June 26, 2008 at 17:37:33 from (216.144.104.128):
In Reply to: SC hydraulic pump posted by Idaho Ron on June 26, 2008 at 16:08:23:
The parts manual has pump numbers and the pump itself has corresponding numbers stamped on it -- they are in the parts manual or www.caseih.com. I believe yours has an o-ring, which is generic and available at NAPA, or better, a bearing/seal business. CaseIH likely has it in stock. If the shaft itself has a deep enough groove in it, you will need a speedi- or redi-sleeve. This requires enlarging the hole the pump shaft goes through. Best to have that done at a machine shop, which can also supply the seal and sleeve. It is a simple repair.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
