bgarrett said: (quoted from post at 09:05:13 07/03/08) I cleaned out the carburetor and got new spark plugs and my H is running smooth and steady but it should have more power. Other than setting the valve clearance, what can I check?
Is it possible to set the timing?
Are you sure it should have more power? Compared to what? H's are only about 24 hp.
Well.... you can start changing sleeves and pistons, put in a 300 or 350 cam, maybe an M&W power govenor would make it feel more responsive??? Is it an "X1" H (serial tag), or a multi-fuel? If it is a multi-fuel, you can change heads to an X-1 head and boost compression, which in turn, will boost power....
Not trying to be a wise-guy, but maybe you really want a Super H or an M? Hope this gives you some helpful ideas. mike
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
