Dont tap into the power steering system. Put a pressure guage in the line going to the cycl on the mower to see how much pressure you are getting. You could unscrew the hose going to the cycl and placing it over the fill tube on the belley pump with cap off. When the engine is running move the handle back and check the flow coming out of the hose that way you know at least the pump is working. If you get a flow place a tee in the line at the cycl and put a guage in the tee.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
