Thanks for the input. Is the pump drive coupler attached to the hydraulics lever? Are you suggesting that where the hydraulics lever screws into the pump (That nut with the cross shape slots) something is not catching and so the pump is not being engaged? I checked that and it seems to be connecting properly. However, it seems like it must be something like that because no fluid flows through the line when the hydraulics are engaged. The rod doesn't exactly flop around but it doesn't have the same resistance or catch in the same place as before. This is a used pump. I got this tractor from a junk yard. The hydraulics were supposed to work. They didn't and they had to give me two other used pumps before I got it to work.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
