6 Gallons 140 wt. - unless you live in the extreme north, then 90 wt. Use GL-1 grade; it will not cause old seals to start leaking.
There is a "full" plug on the left side of the tractor behind the clutch rod. You can fill gear case/trans case until it starts to come out that hole. but, it is still going to be about 6 gallons. Easy to do. Repeat every 10 years.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
