Posted by GordoSD on September 18, 2008 at 11:19:26 from (66.115.200.140):
Took the H out for a shakedown cruise this morning. That new engine with the $400 head, goofy firecrater pistons, just purrs and roars like it should. Just a hint of blue smoke that should disappear when the rings and new sleeves get acquainted.
I have a substantial leak coming out the access hole in the bottom of the tractor. Removed the coupling shaft for the belly pump. Looks like a seal at that forward end of the drive shaft. Behind the flange and in the retainer.
It'd pretty close quarters in there. Can I change that seal (p/n 79634H) working through the access panel hole?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
