Posted by Dave Koenigsfeld on October 16, 2008 at 18:33:10 from (148.78.54.134):
I got a donor tractor for two 10-20s that I am restoring. This donor motor is loose. I rinsed the gas tank out and bled the fuel lines and carb with fresh fuel.
I primed the cylinders with fuel. I have confirmed that there is spark on cylinder #1.
I hooked up the spark plug wires according to the 10-20 owners manual (the wires were attached to the wrong terminals according to the owners manual).
I have not confirmed the correct timing yet. What else should I do to get this old girl firing??? I would love to get it going and then paint the motor and transplant it into my tractor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
