Sounds like you're on the right feature, but I'm not sure it's working: when engaged [yes, down], as LenNH mentioned, you should hear it click at TDC. Once it starts and has enough RPMs it should stop clicking.
If you have someone there to watch, you can pop the cap off and see it too.
Thanks LenNH for putting safety a bit higher priority than I. I need a tatoo on my forehead and signature line on any forum I post to: "Do as I say, not as I do" or perhaps "Following my example could be hazardous to your health." :oops:
edit: I think LenNH was noting: listen for the pawl to drop into the drive, I was noting listen for the mag to snap on release. Same difference, except again, if the mag is turned on [it would be if you're intending to start a tractor] knowing something isn't right before you get to firing position is much smarter!
This post was edited by spiffy1 at 19:13:14 10/23/08.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
