It should click at the top of each compression, so every half crank is right. I thought from your earlier description that it wasn't re-engaging after the first half crank, but sounds like it's all right.
Unless there is crap under the valves, an entirely shot head gasket or something, I'd think you should get some compression (even if it doesn't hold long) with the deep stroke and big cylinders on these things.
I use a sparkplug hollowed out and adapted to an air line quick coupler. If you put each cylinder between 1/3 and 2/3 up it's compression stroke, and slowly give it air (too fast will drive it right back down if any compression exists), you can often hear, feel or see, whether you have leaky exhaust valves, intakes, head gasket.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
