Posted by Dellbertt on November 14, 2008 at 15:36:46 from (209.172.21.127):
In Reply to: #@$%*##$ charging system posted by Gerritt in michigan on November 14, 2008 at 10:27:34:
I"d be curious to know if the gauge indicates zero volts with the engine off then shows negative charge after start and varys with RPM. If it does then just switch the pos and neg ternimals and see what happens. If it shows pos or neg with the engine off then you have a short or incorrect wiring.
There is lots more theory knowledge in here than what I have, but I like to first run test the gen to make sure it is giving off a charge and then work backwords.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
