The easiest is to remove the steering hand pump from the tractor before disassembling it. It can be done while installed on the tractor but if you have never done one before you will be better off removing it first. Also that way you can make sure it is clean before you start to replace the seal.
Remove the steering hand pump. Mount the pump assembly in a vise with the shaft down. Mark the pump housing, sleeve, and end cap so that you will be able to reassemble them in the same position. Remove the retaining bolts. Carefully remove the end cover. Hold the pump together as you remove the metal sleeve and sealing ring. Install the new seal and the sleeve. Reinstall the end plate. Reinstall on the tractor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
