For you guys who call this the 'hand pump'... Might I hope you were able to navigate to the website and see the blow up diagram of the part? Or is this from memory?
In part, the reason I'm asking is I tried to copy/paste the url into browser and it didn't work (dang it). I'm just hoping that someone figured out to go to the case/ih website and was able to look at a picture.
I'm intrigued that this is called a hand pump.
Thanks for your help.
another question if I may...
If indeed, it only needs a new gasket, is that something that would cost say, under $15... here's the REAL question I'm trying to get to....
if it's cheap enough, would it make more sense to buy BOTH of them so I have the right one from the start. I don't want to take something apart and then wait 3 weeks for a part to arrive and not remember how I did it. I'd rather take it apart, fix it, put back together.
Question part II: Is the steering shaft actually connected to this or might I hope the steering shaft unbolts and won't be something I'm having to wrestle with once the hand pump is removed?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
