Posted by David Kronwall on November 25, 2008 at 02:21:34 from (66.191.122.148):
In Reply to: easy M question posted by mikes dad on November 25, 2008 at 01:49:55:
I"m no great mechanic, but I can help you here. On the right side of the oil pan (driver"s right), you"ll find two screw-type check plugs. One is higher than the other. To check the oil level, first loosen the top one. If no oil drips out, check the second lower one. If no oil drips out, you need to add oil. Close the lower one and leave the top one open. Fill until oil drips out of the top one. Then close it. Hope this helps. David
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
