My lift is broken and missing a part. I know that from my Dads Super A. my lift arm from the hydrualics to the lift arm on the blade is broke. It has a rod with a u shape on both ends one hooks to the blade lift arm and the other end that is broke one ear is broke off is now hooked diriectly to the hydraulic arm. You have the 2 pins that are held in by a spring loaded clip. I am missing the part that hooks into the spring loaded clip to the borken ear of the lift rod. the lift rod ear that is still there is in the pin hole for the spring loaded clip. the other hole with the spring loaded clip is holding up the read lift guide bard for my fast hitch. On my dads super A the lift rod has a boomerang shaped piece that uses both hydraulic pins that are held in by the spring loaded clip. If I had the piece for my blade lift then what would the fast hitch rod hook into?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
