Posted by H rookie on December 21, 2008 at 18:08:30 from (74.36.250.180):
I inherited my Dad's farmall H. The early kind, which shipped with steel wheels during the war. He inherited from his father, the original owner. I changed the oil for the first time this fall, and used SAE 30 weight and it seems stiffer than how it used to be. I wonder if Dad used 10 W 30. Is there a way to heat up the engine similar to a block heater for winter use? One more, I put his old loader/snowplow back on it, and the right cylinder drops before the left one. There are two fittings on the left side. I connected to the one nearer to the operator's seat. There is only one fitting on the right side. These are single acting cylinders. Should I have connected to the forward fitting on the left side? Is one a return? Thanks in advance, and Merry Christmas everyone.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
