The ports are all pressure. For your purposes it doesn't matter which one you use. SAE 30 is fine, unless it is consistently below 32 degrees, if so use 10W-30 or 15W-40. Multi-viscosity oils did not exist when your tractor was built. You can also use SAE 30 in the hydraulics, some say to use non-detergent in the hydraulics to prevent foaming -- I always used detergent in our H in the 50's with no problems, though.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
