I misread his post, didn't notice he had two cylinders (a loader would have to have two)-- in that case he should use the two front ones, although they may not lift or lower at exactly the same speed either. Usually the rear port needs a delay valve in it to work properly with front and rear cultivators, but the valve usually did not work for me. Actually, without the valve, if I remember 50 years ago, the rear sometimes came up first.
This post was edited by CNKS at 19:57:13 12/21/08.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
