HEAT - I used a small tin flange, a piece of tarp and an $8 hair dryer.
I made a basket of the tarp with the dryer pointing up at the bottom and hung it with S hooks under the oil pan. In about 20 minutes it starts every time.
HYDRAULICS - I only used the single on my H. My neighbor had an H and M with loaders. He used a splitter on one port to run a line to each cylinder from one port. He used it that way for years. Using two ports you are always going to have at least a slight pressure difference. I wouldn't change it unless it is really bothersome.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
