Posted by AFM on December 26, 2008 at 08:52:09 from (208.74.247.249):
Here's the situation. My dad's 400 in cold weather, 20 or below, has to have the throttle almost closed and then very little choke to start. Then it may go, or it may appear to flood, gas runs out of carb. I have tried many combos of choke, no choke, throttle different positions and usually the combo of very little throttle and little choke gets her going. Then once running adjust choke as needed for a minute or so and then push in choke. It wasn't always this way, last several years always started with choke 1/2 ways and throttle partially open no problems. Any thoughts on what may have changed?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
