Posted by Clarkbug on December 27, 2008 at 19:59:20 from (209.23.8.100):
In Reply to: Stuck BN's - Update #1 posted by Clarkbug on December 27, 2008 at 14:27:03:
Thanks for the offer Old. If I get to that point, Ill make sure to look ya up.
Ill have to check the adjusters to see where things are. My guess is that someone did close them, since most seem to be out and just a few are moved. Last I knew you adjusted the valves by starting with #1 at TDC and then move through them one by one, right?
If I do have any cracks in the block, are there any that are OK, or are all of them a reason to scrap the block?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
