Posted by Janicholson on December 27, 2008 at 21:33:55 from (64.83.200.187):
In Reply to: Stuck BN's - Update #1 posted by Clarkbug on December 27, 2008 at 14:27:03:
I Think the lifters are all rusted into their bores. The result is that they all stay in their raised position and the valves all seem to be pushed at once. I have seen it on two engines, one was a SC, with that same series of block. I took a week of tinkering and rotation with PBblaster to free them, and then remove and clean the bores while keeping them in order. It was worth it. But if it is cracked, it is for sure a call that needs to be made. These engines are common enough to find a good one rather than make a patch job. JimN
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
