If the Torque Amplifier is not working (on the reduction position) it will not move. If the TA has a handle (some get removed) it will be on the left side of the operators platform and just in front of the axle. It is about 30" tall, and has a flipper release on the back side of the hand grip. Put this lever forward if it is back. (do not do this with it running, do it before trying it.) The TA in direst drive has a small clutch (similar to the main clutch, but not as big) which drives the whole tractor in direct drive. If the TA clutch and ramp and rollers are both out, it will not move either position of the levers. This is the most likely issue. A TA rebuilt will cost about 650 to 700 W/O labor. Sense you had the clutch out already, you know how to split the tractor. The TA repair requires splitting one housing rearward. of the first split. If the TA levers and linkages are removed it may be necessary to remove some inspection cover/s to look at movements. If it is a TA delete tractor (which is unlikely) the above info will not apply. A twisted out axle keyway on either side will also produce no movement of the tractor. Blown internal trans gears, or differential gears are also possible issues, but less likely. Do some diagnostics and get back to us. JimN
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
