Posted by Saw Dust on January 08, 2009 at 11:30:28 from (137.186.131.225):
Hi, Me agian.... hopefully I am not asking too many questions but you guys are a goldmine of info... Thanks so much.
My next problem is I realized that the fuel pump on my IH2444 has been bypassed. The line comes right from the tank goes through and in-line filter and into the carb. In other words it is gravity fed. The tractor runs well as is but I am concerned that on a steep hill the level of the tank may be below the level of the carb and the tractor will starve for gas. Is this a valid concern. I noticed the fuel pump is located much lower than the carb. I think there is a good reason for this. Also there is no bowl type filter in the fuel supply. How necessary is this type of filter? If the fuel pump does not work can I use a generic electric one to replace it with (It is and electric pump now I think).
Thanks again for your advice. Hopefully one day I will be able to give a little back to the forum instead of just take.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
