Posted by jdemaris on January 08, 2009 at 15:38:13 from (72.171.0.148):
In Reply to: bc144 valve oal posted by exjetman on January 08, 2009 at 11:50:03:
I've got some used valves around, but it might be a day or so before I dig them out. They're still in a head I pulled off a BD144 in a B-275 tractor. BD144 diesel uses the same valves as the BC144 gasser. 3044174R1 and 3044175R1.
I know where there are a couple of used heads, but none will be cheap. Prices are getting out of this world. Tractor junkyard near me has a 3414 and a 354 tractor, both with BC144 engines. I was looking for a spare carburetor to rebuild (British Zenith VN or VNN). The place wanted $200 for used carb that had been out in the weather for years. $50 would of been high. I finally found a place in England that has them brand new for $140 each.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
