Posted by biggerred on January 14, 2009 at 19:19:22 from (74.177.51.224):
Just got a 53 Super M (stage II)and am learning all the differences from the 52s. This one has the live hydraulics with the res. under the gas tank where the battery once was. It has a valve purched on top of where you use to fill the old belly pump. This model has what I assume is a second res. where the old pump once was. Does this valve configuration bypass back into the upper tank as well as a lower tank? Bare in mind this is factory stuff, not some cobbled up job. The valve is loose at the base where it goes into the lower tank, and I need to disassemble all this to tighten things back up. There is no guidence at all in my IT manual for this type set up.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
