That pump # is for a diesel. Type pump used by IH gas engines is a fairly easy bolt up if the M engine is serial # 228083 or higher. There's more than one way to make it work if lower, but takes more work if serial is lower and nothing has already been changed. A port block can be got aftermarket, made, or from another IH tractor. You should use a pressure relief valve in system and if you don't need the extra pressure set it at 1000 PSI or a little lower and whatever cam gear you have in engine may last. Disclaimer, Some information from IH and other sources can have conflicting answers. Also all parts of units in question are subject to changes by dealer, others and end user. Above answer is made in good faith but with no guarantee to be correct.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
