pull a spark plug, hook it up to the plug wire, lay it on the motor so it is grounded and crank it over. you should have a good blue spark. if not, pop the cap rotor and dust cover off, hook the end of the spark plug wire into the coil, then with the ignition on, open and close the points. you should get a brite blue spark, if not sand the points lightly with some 320 or 400 grit paper and try again. if not, i'd start looking at the condenser, or possibly a short where the wire goes thru the distributor and connects to the points.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
