Check the insulator on the bolt that goes through the distributor housing. Had a similar problem with my H, did a whole bunch of stuff to try and solve the problem, and FINALLY found the bake-a-lite insulator was cracked. It took a plastic insulator that the parts man @ local NAPA came up with to fit the hole & the bolt, as IH didn't have the bake-a-lite insulator, I think it was a Datsun distributor part. Its been in there for several years w/no problems. (My $0.02 worth. jal-SD)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
