Re: 504 odd backfire
Posted by the tractor vet on February 15, 2009 at 08:31:08 from (76.212.226.84):
In Reply to: 504 odd backfire posted by R.J.J. on February 15, 2009 at 07:29:09:
Have you checked the ing. timing ??? also check the mechanical advance in the dist for a broken spring or to much slop in the flyweights . Next if you are not running 93 octane gas in it as it is one of them engines that needs the better gas s it was built when the gas was better and a higher grade then today . 87 octane burns way to hot for a working tractor . Run the correct heat range plug. use only low ash oil .
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
