Posted by gene bender on February 17, 2009 at 19:47:32 from (67.55.226.75):
In Reply to: A/B Head difference?? posted by Rob Bush on February 17, 2009 at 11:59:50:
Earlier heads had a narrower opening around the spark plugs which was changed in Jan 40. Heads are all the same otherwise. Pistons were kero,gas,5000 and 8000 so dont worry about heads being different
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
