Posted by Tom in Iowa City on May 07, 2009 at 16:44:57 from (173.21.35.134):
1941 Farmall A. The LEFT rear is leaking, such that the rim is getting quite oily and the wheel is also getting oily. I have the rear wheels, rims and tires off. I think there could be only 3 sources for a leak: 1) the left hand shaft, leaking out of the bearing cover, 2) the axle or 3) the pan. A couple of months ago, I removed the pan and its gaskets, cleaned up the mating surfaces, cut a new gasket and replace the pan. In looking at the pan, after removing the wheel, I see a pretty good leak from the left side of the pan. The axle and the shaft seem to have very LITTLE leaking. I know I tightened up the pan machine screws well, so my conclusion is that the pan may NOT BE FLAT ON ITS MATING SURFACE. Do you agree? I will remove the pan and check. I did NOT check for flat when I did the work on it previously. If it IS out of flat, what about using some gasket maker silicone liberally on that area and then replace and tighten? Thanks, Tom
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
