Posted by SDE on May 09, 2009 at 20:00:13 from (98.125.99.141):
In Reply to: 400 hard shifting posted by tonastoy on May 09, 2009 at 16:42:46:
When you step on the clutch pedal, it will release both the engine clutch and the TA clutch, if they are adjusted properly. Yours is most likely not releasing the TA clutch completely. Due to age and wear, you may need to adjust the TA linkage to different specfications than what you find in the manual. Continue to adjust until it shifts properly. SDE
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
